1 - 3 of 3 Posts
As the subject reads, was just wondering about this since ive heard about this. My car is a daily driver so would this make it unbearable to ride in if done?
Zettai Unmei Mokushiroku
If you mean welding the engine mount closed, it will work fine if you have a manual Celica. There will be a small vibration at idle, but you should get used to it in a day or two. If you have an automatic, though, it will create an unbearable shaking at idle.
If you do this, make sure to leave a little room around the edge of the center of the mount so it can flex a little. You also want to fill in the open space of the mount with something like polyurethane or silicone.
1 - 3 of 3 Posts
