1 - 8 of 8 Posts
Well I went to the dyno today to find out why my car has been running VERY lean lately.
I pulled three runs
One baseline
One with new plugs
One with new Plugs and Disty cap
I netted some damn good numbers but my car was running VERY lean as indicated by my A/F gauge and the dyno proved the A/F gauge reading to be correct.
I had a problem with my FP regualtor, I did not figure it out util I got home, pissed trying to figure out why my car had been running so lean lately. When I first installed the SC it ran rich, too rich actually, now it was the opposite, with nothing done to the car since.
I thought the dyno would help me figure it out.
Well after I got home from the dyno I decided to do a FP check. I had set the Fuel pressure to 45psi at WOT a while ago, but for some reason when I hooked up my FP gauge it only read [email protected]!!! Holy ****.
Somehow the screw got loose and over time and bumpy roads the screw had unwinded, resulting a a very low FP.
So I re-set the FP back up to [email protected] and the car feels MUCH better now.
If it was'nt for the 12:1 FMU my engine would be toast right now.
now my A/F gauge reads in the green and my car feels and runs much happier, just smooth acceleration.
I only pushing 6 psi.
Im sure that just with the Fuel issues resolved I gained a good 10hp and 10lb TQ.
How does almost 300HP to the crank sound???? heheehheahahh
My car weighs 2600 lbs with ME in it.
pic doesn't work mike... what were the numbers? i wanna look at the shape of the curve...
R
Discussion Starter #3 (Edited)
pic works now...sorry
252hp to the wheels
247tq to the wheels
I know it's a lil shkay but thats was due to the very low fuel pressure.
Damn, at only 3500rpm I am putting 150tq to the wheels and at 4000rpm I am putting 175 to the wheels!
As you can see the SC hit peak TQ at around 5200 rpm which is a bit lower than I expected but the HP climbs like a MOFO to almost 7000rpm
keep in mind that I have done NO tuning except bolting on the SC
the torque curve seems to fall abruptly right after peak... i wonder if you are holding boost all the way to redline...
R
the 3SGTE is on hold again... the suspected oil leak wasn't coming from the oil return line from the turbo, so i need to determine where it's coming from now... and having the motor all taken apart with oil spilled everywhere doesn't really help either...
R
nice numb ers mike......bring that to florida and run it!!
Discussion Starter #8
R
The tq drops off so quickly after peak because I was running out of fuel, the fuel pressure was too low to compensate for the added spark and the car started to bog out thus losing boost.
I have since resolved the fuel issue and I got some higher flowing injectors to drop in on the way. I should be able to push close to 10lbs with the higher flow injectors along with my high flow fuel pump. Should be another 20-30hp to the wheels EASY
I have since done some recent G-tech passes ( no tracks open yet) but my trap speed on the gtech has gone from 108mph to 114mph) 1/4 times are just a bit quicker (12.7's) but Im not testing 1/4 mile ET's just traps because the ground is too cold to try and lauch with 240lbs of tq to the front wheels good lord!
1 - 8 of 8 Posts
