1 - 3 of 3 Posts
i got totally worked over at the car wash last week (i live in pa and it was cold and salty). they put a huge L-shaped scratch in the middle of my hood with their scrub brush and i think they cracked my headlight b/c i noticed water inside the ehadlight when i got home
is there a way to get the water out from inside my headlight?
and what's the best way to get a nasty scratch out?
thanks for your help
ouch man that sucks...have you gone to the car wash and said something...??
have you tried to wax out the scratch at all???? if you cant then i am thinking paint...:(
are you sure the headlights are cracked??? cause some celicas have had problems with water or condensation getting into the headlights and you could "search" on that....
the other day i read in the manual (section on changing headlight bulbs) that the fogging up of headlights due to cold weather is normal. but if there is a drop of water inside the headlights, then there is something wrong. in your situation, i would go to the dealer and try to get them to replace your headlights under warranty, unless you can somehow solve your own problem by opening the headlight assembly.
1 - 3 of 3 Posts
