1 - 4 of 4 Posts
Is it 10A or more?
I just bought a headunit that supports both 60w x 4 or 40w x 4.
Will it be ok if I hook it out 60w x 4 with the factory speakers?
Discussion Starter #2
I am copying this off the manual, what does it really mean?
-Connect the accesory (long red lead) to an accessory circuit of 10A or more when the vehicle engine switch is set to the ACC position. If the current is less than 10A the accessory fuse on the vehicle may be interrupted.
Basically it means to connect it to a power source that has a 10A or higher fuse on it, best bet...use the factory power wire.
1 - 4 of 4 Posts
