Anyone have any idea what that circle plate is? I put in a brand new suspension in the front with brand new strut mounts and that metal circle piece clunks. I can spin it and push on it but the passenger side is stiff as a board. Thanks!
I took it all apart and installed the new parts exactly the same. Under that piece is the strut mount and in the middle is the nut. Except passenger side doesnt move and that side moves. Previous to this the driver side did clunk but i thought with all new stuff it woulf disapear. It appears that this piece is what has caused the clunking from the beginning
You need to tighten the nut in the middle probably. You'll need to hold the shaft in the center and use a wrench to tighten it or have a shop do it for you.
The noisy plate looks like an adapter so the strut mount can be bolted up to a smaller diameter strut tower hole if necessary.
Or something.
Interesting.
Dentman
1 - 17 of 17 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
