playing with a carchip e/x today, i observed some interesting things.
brief: this devide sees what the ecu sees. the #s are as accurate as the metering device.
took out two 2000 GTSs on the same road within a 10min span. both have trd exhaust. #1 has stock intake with k&n filter, #2 has aem cai.
after idling at the lite, #1's intake air temp was up to 64.4F. after driving around, the lowest reading was 46.4F.
after idling at the same lite, #2's intake air temp was up to 42.8F. after driving around, lowest reading was 30.2F. (exact ambient temperature unknown, reported mid to high 20s)
i've noticed with cai that air temp remains more consistent thru stop/go driving, where as with stock airbox air temp increases more dramaticaly while the car is stationary.
throttle position on #1: min 11%, max 78%
throttle position on #2: min 10%, max 76%
possible this is just a matter of scaling for the ecu, 10=0, 78=100 ?
at WOT, short term fuel trim = 0%
most adjustment in short term fuel trim seems to happen while speeding with no throttle.
[more to come..]
[more to come..]
