1 - 20 of 20 Posts
Is the stock offset 39mm? Would a 36mm offset sit flush to the wheel wells? If not, what offset is the best for the Celica?
Before you flame me, I did a search and didn't come up with an answer that I was looking for.
It depends on the width of the rim. I have 7 1/2" wide rims with a +35mm offset and they are flush with the wheel well.
The rims I might be getting at 17x8. I gotta call them up and find out what the offset it. Thanks for your help.
That is the EXACT size and offset i have on my car.. its pretty darn flush..
btw, you cannot go any further out than +35 offset w/ 7.5" width or else it will rub the fender.. mine is almost touching the fender on the outside.. so if you go any wider, you'll probably need to roll them
StreetFighter said:
The rear wheel in your sig doesn't look to be flush with the wheel well. What offset would you think correct that?
i think the rear panels flares out a little more than the front cuz my fronts are flush
I have 18X8 with +35 offset. It is perfectly flush. In fact, I was worried it was gonna rub. Sups' car appears to have too much rear camber. My camber is set at -1.6 degrees front (with crash bolts) and -1.3 degrees rear.
i'm getting 17x7.5 w/ +48 offset
i'm going to slap on wheel spacers.....I'm guessing 10mm so it'll be 17x7.5 w/ +38 offset right?
they willl stick out toooo much...and like chiznarles said:
you cannot go any further out than +35 offset w/ 7.5" width or else it will rub the fender... so if you go any wider, you'll probably need to roll them
No, you are wrong. Read above posts.
1 - 20 of 20 Posts
