1 - 20 of 20 Posts
I have 17x7 Kosei K1-TS good light wheels on my celi but I can not identify offset.
Can not find where it is written on wheel. As I know, wheels are from Subaru and based on sellers info on web K1-TS 17" for Subaru have 50mm offset.
Now I'm trying to fit H&R DRM type replica 25mm spacers on rear.
But with 25mm spacers my 215/45/17 tyre bumps to fender.
Will be 20mm ok for rear and front in my case or still to much?
How can I recalculate offset from stock 16x6.5 et38?
How much possible for stock 16x6.5 for rear and front?
Dont offer to me to change wheels ;)
Subaru wheels will fit on your celica if your brakes are stock. No spacers need. Just remember that the subaru is a 5 lug, so if you are not a GTS you wont be able to use the wheels. Cheers.
Ultraviolent
Best offset for us is 35, so IF u are at 50 right now go with 15mm spacer, btw where did u find that replica spacer? I want a 10mm for my rear
I have my Kosei's for 3 years :) and now want install some spacers to increase wheel base. Only now I found that my offset are far away from stock.
Will 20mm spacer fit in my case or I must use 15mm?
Replica we made ourselves, quality as original ;)
U can use a 20mm spacer, but youll most likely rub when cornering hard or if u have the steering wheel fully locked
you mean, when front wheels will be turned to maximumum? btw.. I have drop -40mm. So, more safety will be go with 15mm?
et50 x7 wheel VS et35 6.5 wheel = practically is a stock position?
i thought that all gt and gts had 5 lug.
all 7th gen's uses 5x100 regardless of gt or gts
so true, and i have a gt and it is 5x100
Discussion Starter · #16 ·
I've made 20mm spacers. Bad :marky: , stock studs to long and my Kosei wheels dont have holes inside. Only way is to cut 5mm of stud about. Made mistake :( I'm hesitating :confused:
Pics... Show pics... I'm trying to find out the offset of mine too, getting 18x8 with 48 offset, I think with 10mm spacers it should bring it down to 38, which is about as best I can get. If you can get 15mm spacers then i'd think they'd be best but you could maybe go more.
If you took 10mm off of those, they would literally be perfect, would that not save the problem with the studs being too deep?
If you shear too much off and they go down to 13mm they'd be perfect for my wheels hint hint :D lol
1 - 20 of 20 Posts
