:ugh:Originally posted by aZnTrD2k
Does a wheel adapter exist to make a 5x114 pattern wheel fit a celica?
That's WRX STi with supersize calipers offset. :AF:Originally posted by Goldilocks
azntrd2k1,
I have those same spacers. I bought them before I decided not to be a cheap ass and get some custom rims to fit my widebody. If you're thinking about getting them to fit on a stock body celica, you may want to think about this...
You will need to add however many milimeters the spacer is to the fitment offset. For instance, on the celica, you are looking at an optimal size of 17x8 +35 offset. With the adapters, you will be looking at 17x8 +65 offset. This will look kinda odd.
Your other option would be to pop off your hubs and have a machine shop press them into a 5x114.3 bolt pattern. My boyfriend used to do this with trucks back in the day.
Hope this helped!
Keep rollin!
why yes i do!Originally posted by aZnTrD2k
you stilll have them?
+65mm offset because of diff calipers?! that's crazy, almost insane that means that your rims will have a weird ass curve to them, i dunno... i'm just a girl, i probably don't know what i'm talking about, right?
why yes i do!
Are you using them now? Can I borrow to see how far my wheels will stick out?Originally posted by Goldilocks
why yes i do!
They will sit 1.18" (30mm) farther out than they do right now.Originally posted by aZnTrD2k
Im waiting for the new 5zgien FN01r-cs(black polished lip) co come out. I dont know what size/offset they come in. All i know they told me they wont come in 5x100 bolt patternOriginally posted by Goldilocks
Let's start off with this... what size and offset 5x114.3 wheel are you planning on putting on? I'll do some measurements and tell you exactly how it's going to fit!
My boyfriend used to work for Zigen and he said he'd go and check on Monday.
You can have the redrilled to any BP that you want.Originally posted by No Camo Celica
I'm not sure so ...is there a way to swap out the wheel hub and brake discs in order to have a different ( 114.3 ) lug pattern?
