1 - 4 of 4 Posts
so i had the same setup for over a year. i took my car to the shop to get tuned and get a custom bracket for the actuator made. when i got the car back they had it tapped a different way. i think its basically the same source, but i just want to make sure.
here is the pic:
i had the original set up coming from where the little capped off nub with the zip tie is. their set up is coming from the nipple on the IM with the silver hose(T'ed to the actuator).
thats the same source, correct?
its normally recommended to put the wastegates vacuum source befor the throttle plate so in other words where you had it before if I understud you correctly where the black rubber cap is with the zip tie.
so can anyone tell me what is bad about running it before the throttle plate? it seems to be running fine, but if there is some behind the scenes badness, id want to change it.
1 - 4 of 4 Posts
