1 - 10 of 10 Posts
I found a spot for the ballast on the left side under the headlight straped with a bunch of zip ties but where did every body else strap there right side ballast.
I tried sticking it behind the power steering tubing but the ballast was getting way to hot that close to the engine and it will get wet almost ever where else.
HOW?????
The windshield washer reservoir is in the way.
there is a space between bottom of the headlight and reservoir. I double taped one ballast right on top of it. the other one on top of wheel well. there is also a space between headlight and wheel well. Also hangs on double tape.
Yeah i did the same, zip tied under lights on the wheel arches. Kinda dodgy but was in a hurry to get it done.
O_o
Um, I don't know, I just slid them up under and ziptied them in :confused:
Passengers side:
Drivers side:
i just lefy mine under the headlights and didn't tie them down.... they don't move around or make noise!
I have my driver's side hiding down below where the brace bar is, and the passenger side I have right under near the windshield washing fluid funnel.
Discussion Starter · #9 ·
the left one I had firmly zip tied down to some holes under the headlight and dam I had to take it out because if failed (under warranty)
But the right one.... for those of you that put it to the right of the headlight. I found that it gets way to hot around there.
Man.... I need to get some power tools and drill some holes in the metal beside the reservoir. Behind the bumper.
Mine under each headlight and attached with velcro. I pulled all the stock surrounding wires away from the ballast just in case.
1 - 10 of 10 Posts
