OK...im not sure if this is normal or not..but..say..im going 65mph on 6th gear..the rpm is at 3k or so. When i decied to go full throttle(without downshifting)...my rpm jumps up about 1.5-2k...then drops down about 1-.5k...all this while on full throttle. After this happens the rpms climb like normal. SOO..basiclly it jumps up then drops down a little..then climbs up normally. This also happens on other gears as well. Like i said..im not sure if its normal..cause i dont really full throttle it when i want to accel dramaticlly. Its not a low RPM thing cause i tried it around 5k and 6k.
