Nice guide. Didn't think of doing that.
PM Larry so he'll move it to the Install section.
It did seem a bit tougher to remove than some other LEDs, it probably is glued, but I just thought it was that I wasn't reflowing the other end fast enough. Here's what I did to remove it: I alternated heat on both ends with a 40watt radioshck soldering iron having a 15 watt tip (tips are just metal, yeah I know this is ghetto, but it heats a lot faster than a 40 watt tip and helps reduce the overall soldering time for most components) and gently pried at it with a jewelers type screw driver and it came off without tearing up any traces. I suspect the adhesive is weakened by heat, so take your time and alternately reflow the solder on each end while pushing/prying. Care should be taken not to lift a trace, or do other damage.I've tried to remove that led but I was told it is glued on by some members here. Any thoughts? Should I just soldier an led on top of the stock one? Any help would be appreciated.
