i know i can do that but i would like toOriginally posted by BrianGTS
pull out your center console and check and see if they tapped the two lock wires right at the switch there. If they are, then you need to program the clifford to pulse twice on the unlock circuit when pressing the unlock button. Programming options are located in the installation guide.
haha sorry for my incompetenceSQ GT-S said:The place I'm talking about is behind the drivers side kick panel with all the plugs. On one plug, there are the two yellow/black wires. That picture looks like the center console?
Curt
um theres no point of looking there cause u still gonna have to program your unit to send out a double unlock pulse.. unless u go to the center console behind radiosheizen said:ok i found the two wires that my alarm is spliced into. one is yellow and one is brown.
from what i can see it is the ones in the pic below.
what will i be looking for behind the radio?CeLicAxTrD said:um theres no point of looking there cause u still gonna have to program your unit to send out a double unlock pulse.. unless u go to the center console behind radio
As I previously stated, I have the Clifford 8000 installed in my car, which is basically the same as the 9000. I do NOT have a double pulse coming out of my alarm for the door locks. There is a single yellow/black wire that will unlock all the doors with a SINGLE pulse.Originally posted by CeLicAxTrD
