1 - 8 of 8 Posts
Looking to take my 2000 GT-S 6 Speed manual back to stock, currently searching for a good deal on the Right ECU and Exhaust Manifold.
89666-20082
or
89666-20083 for the ECU, the 83 is the TSB fixed one, preferred, but don't know availability.
and the stock exhaust manifold, according to this nifty guide by DDPR
https://www.ddperformanceresearch.com/admin/pdf_files/ZZ_Exhaust_Manifold_Identification_guide.pdf
could be 1 of 2, either original 2000 GT-S, or the revised one with air-inject block off tabs.
Reply here or PM me and let me know, hopefully someone has these kicking around and would be willing to part with them
Thanks for reading!
Discussion Starter #2
Currently Talking with a nice gentleman on the Spyderchat forum about the exhaust manifold, but I'm also updating my list of ECUs
89666-20081 Original
89666-20082 New p/n
89666-20083 TSB updated
Either of the 3 will work, I believe they are all the higher Rev limiter? Hopefully can get it for a reasonable price... Had someone offer me one for $618, double the cost from MWR, might just have to go with MWR if one doesn't crop up
Thanks for reading!
Whooooops... Looks like I didn't do my research properly...
No longer looking for the 89666-20083 ECU, according to things I'm reading it has the lower Rev Limiter... Which is NOT what I'm looking for. At least I found out BEFORE I found one. Apparently there was a limited production 89666-20080 that also works, but is hard to find.
TL;DR
Looking for only 2 ECU's still:
89666-20081
89666-20082
Also 89666-20080 would also be acceptable, but with such limited production chances are slim
Thank you!
Discussion Starter #5
Purchased 2ZZ ECU, 89666-20082 from a gentleman on Spyderchat, talking to Speck now about his exhaust manifold, and Mighty Mouse about his. MM might be using his for his 2zz swap, so almost there!
Discussion Starter #6
Purchased and Received 89666-20082 ECU from Spyderchat from Espyderman, well packaged and seems to be in good quality, A+ service!
Still looking for the exhaust manifold, original guy backed out but I'm talking to Speck currently about his.
Discussion Starter #8
Received exhaust manifold and heat shields from Speck, great condition and fast shipping, A+! This WTB ad can be closed, I'll be starting another one here soon for other parts I've found I need. Thanks for all the help and replies!
1 - 8 of 8 Posts
