Im in the market for some coilovers atm and I'm trying to decide between getting the Zeal B6 or the V6. In both cases, im probably going to go with the BASIC spring (rather than the swift), just because im thinking that the swift springs will be too stiff (i have a set of 19s with low profiles coming as well).
Which one do you guys think i should go with?
On a side note, the only other 2 coilovers i think are worth considering are the tien SS-P (w EDFC) or JIC FLT-A2. But only because these are cheaper and in the case of the teins, i have an audio setup covering the spot where the dampener adjuster knobs are...so the EDFC will be quite useful.
Thanks in advance.
Thanks in advance.
