1 - 4 of 4 Posts
I was looking at the Zex Nitrous wet kits and it says they have a WOT switch so you are only spraying when your at Wide Open Throttle and it stops the spray when you let off. Is this a good idea or should I invest in a Window Switch and program it to spray in at a certain RPM?
Most people do both as a safety mechanism. I've got it set on WOT with a mallory switch from 2700 to 6400rpms
Is it even a good idea to spray for a duration of 1500-2000 RPMs? I was planning on using it at the 1/4 tracks and having it spray at 5600RPM to somewhere around 7500-8000RPM. Good idea? Would it still spray if I shift and the RPMS landed higher than what I set it at?
if you dont lift of the gas to shift it will still spray.it should turn off at your high set point if you overev . they say its not a good idea to spray under 2500 to 3000 rpm. but i have sprayed wot straight from idle before.but i dont have a window switch and have a 1zz.
1 - 4 of 4 Posts
