Cargo Question
1 reading
871 views 14 replies 7 participants last post by  Ripz
#1 ·
This fall i'm buying a 2001 toyota celica gt-s six speed manual. I'm going to put subs in it, but I can't find the cargo dimensions on the web. I want to put in two 15" FI BTL subs which requires a lot of space.
Below is the info on the sub:
DUAL 2
Fs: 36.3 Hz
Re: 1.4 Ohms/coil
Qms: 7.14
Qes: .28
Qts: .27
Mms: 275g
Sd: 810cm^2
Vas: 64.4 l
Spl: 92.4dB1W/1m
Bl: 25.1 N/A
Xmax: 28mm *
Rms: 2000W *
Sealed box: N/A cuft
Ported box: 2.5-5.0cuft
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 9.625”
Displacement: 0.14cuft
What I really need to know is the length, depth, and height of the trunk. If anyone could get the measurements for me it would be greatly appreciated. I know that the cubic foot is 16.9, but that doesn't do much for the other things I need to know.
Thanks. :whip:
#5 ·
Should fit just fine. I used to have a 4 cu. ft. Ported box in the back, had some room left over. It'll all depend on the box you get though. I think it's like 3.5 ft wide at the narrowest, 3 ft deep and 2 ft high. Removing the cargo cover could net a few more inches. Keep in mind that this is just my estimation, don't have the celi near me at the moment
#9 ·
True story.
Unless you're going to upgrade your ENTIRE system to make it loud enough to hear anything over those subs it would be a waste of money. Also, you'd go deaf pretty quick! I have 2 12" Infinities in my truck in a box that's about 3 feet long, 1 foot tall and 1.5 feet deep. I have decent space in front of them for other things, especially if I put my seats down. I have my amp at normal low settings and I have my bass/subs turned down all the way on my head and it's sometimes still too loud for quality listening. I only have a 720 watt amp too.
Be realistic with your subs, you'll look like a fool with a rattling car and no one wants to hear whatever the heck you'd want to bump on 2 15s!
