1 - 4 of 4 Posts
freegts
Discussion starter · #1 ·
Ok, so right now I'm in the middle of putting in a new clutch, according to the tech manual, there are two different part numbers for special grease used when installing a clutch, one of them is labled "Clutch Spring Grease", and the other "Release Hub Grease". Does anyone know any equivalents to the factory stuff? Is there anything I can substitute for the Toyota Grease? I'm also wondering what type, if any, Loctite you used on the flywheel bolts and the pressure plate bolts. Any help as soon as possible would be greatly appreciated. Thanks in advance!!
~Bruce Wagner
really?
use any hi temp grease on the collar that the TO bearing slides on, put some on the spring where the TO bearing snaps on the fork. and some on the splines. thats it
really?
Yeah, I just wanted to give this thread an answer because it comes up when you search for the exact words according to the repair manual.
Now any other poor sap that searches will have an answer. Thanks :)
1 - 4 of 4 Posts
