what is the difference between 0w30 5w30 10w30. I live in california. Most of you use 5w30 on the celicas but why do oil change places use 10w30? what do you use for vans?
Nope. Autoxr explained it though.Paeday said:if i remember 5-30 means good from 5 degrees celcius to 30 degrees celcuis and so on for 10-30.
It happens every now then. Usually when the topic is more technical and less subjective. We both know our stuff.autxr said:I mostly agree with yakkosmurf (a rarity).
The first number (5 or 10 in this case) is the cold viscosity, 5 really isn't too thin even in exceptionally hot weather, however, 10 isn't too thin either.
The second number is the HOT viscosity, so once it's warm, a 5W-30 and a 10W-30 are exactly the same.
Here's the difference. Typically the narrower the viscosity range, the more uniform the oil composition is. Often modifiers (non-oil, non-lubricating) are needed to make the oil perform at the advertized viscosity. The modifiers are the first thing that breaks down in the oil, so a narrower range is better.
That being said, with modern oils, they often get the viscosity range advertized simply by changing the oil formulation, without the use of modifiers.
The only reason I would see to go with a 10W-30 is if you have an older car and it was making noise (rod knock, lifter rattle, etc) with the thinner oil. Even so, that would be more a function of the hot viscosity, so you would need a 40 or 50 wt oil.
Scott
