OEM Flywheel bolts torque specs?
32K views 10 replies 6 participants last post by  kortik
The two upper ones that bolt from the tranny side into the engine block ar 47 ft-lbs.
The two middle ones on the differential side that bolt from the block into the tranny ar 35 ft-lbs.
The two lower ones that bolt the block girdle to the tranny bellhousing are 17 ft-lbs.
im sure these are correct, i use my highly calibrated elbow grease and just make them tight.
oh and the starter bolts will probably be in the 35 lbs range too
