Ok guys, hopefully some of you wheel geniuses can help me out with this one. Here is the question I have..
Say you find a 17" wheel that weighs say 4 lbs heavier on each corner as the stockers, but maintains the same rolling diamater (40 series tire or less)
Then you happen to come across a 18" wheel that is say 3 lbs lighter on each corner, but it uses 40 series tires instead of the normal 35 series to maintain stock rolling diamater. Which is the lesser of the 2 evils?
I understand about the rolling diamater and how important that is, but another question that brings up is this. Where is width in this whole equasion?
What I mean is, If you have a stock 16" w 55 series tires is exactly 17.5" tall (for example) but that wheel is 6.5" wide.
Do you lose hp or anything by going with a 7.5" wide wheel, but weighs the same and is the same 17.5" tall?
hope this makes sense to some of you. I would really like to know what your responses are.
Thanks
Thanks
