wut spacers for rota subzero?
775 views 5 replies 5 participants last post by  TaeMachine
#1 ·
rota subzeros, with +48mm offset
wut mm spacers do i need to make it fit my gt??
thanx guys
#3 ·
I assume you are looking at 17" wheels. 18s can be had in +45 which is slightly better for the Celica. Rota is big on Subaru sizing.
8mm spacers will bring the offset down to +40, compared to the +39 offset on factory wheels. With a 7.5" width on the Rota wheel, figure it will stick out (and in) an extra half inch from where the stock wheels are normally. That's probably good enough, depending on your preferences.
Spacers I don't claim to know everything about, but as long as it's the correct lug pattern and centerbore (you should be getting hubcentric spacers) then one should work as well as any other.
