hey wat do u guys think about doing a 2zr engine from 09 corolla it has cvt contious vavle time adjustment and it has a 10 compression ratio on the pistons so i think this would be a great swap for f.i? i mean if our c60 tranny bolts up and the engine mounts are the same but im pretty sure they should be the same since they did have a 2zz and 1zz in before i doubt then changed the engine mounts, so i wanna hear anything good or bad things people know about this engine i mean id rather get swapp this engine and boost it if its possible to 400whp then building a 2zz cuz 2zz is expensive to build even thou i have a new one sitting in my garage and im thinking it should be fairly cheap to pick one up at junk yard in about a yr?
