Hub change: 5x100 to 5x114
33K views 52 replies 28 participants last post by  cuttyman9
#1 ·
Well i know alot of Hondas do it to convert their lug patter from 4 lug to 5 lug. I also did a lil bit of research and found that we can change our hub to 5x114 by using the Avalon hub. They also have the drum and disk in the back from what i remember like the GTS. I was thinking if we chance the hub to the Avalon hub.Yes I know they make a spacer to change the lug pattern but I feel this way may be safer and i don't feel right adding on a spacer to a bigger spacer. How much would this cost around? and is their anything else that might need changing?
Havent heard of a celica doing it so thought id bring up the topic. :gap:
#53 ·
I'm trying to do this as well. It is not in the cards to use a spacer because I do not trust them with any sort of spirited driving.
If it were as simple as buying a set of wheels custom I would try to do that but spending over a grand on wheels is out of the question.
also to note, I'm working with a 5th gen.
This is flat out the simplest, probably cheapest, safest solution. All that is needed is a list of what works.
so far I've found that the rav4 hub works but needs the hub diameter trimmed to what a camry hub center is to match a camry rotor.
In the rear I believe the camry rotor and hub should bolt right up.
It would be simpler and cheaper to know if the camry hub would work up front instead of the rav4 one because then it requires no machining of the hub center and should press in without problems.
Lastly the final product would allow for using any 5x4.5/5x114.3 wheel and also match the mk4 supra hub center diameter.
So if anyone has attempted installing any of these pieces, I would definitely be interested in knowing how it went.
I should be hitting the junkyards soon to see how the camry hub swaps to a celica rear drum assembly.
#38 ·
So while I am in the process of rebuilding my front axles and hubs, I found the stock bearing, part number 363-40066, that the hub is pressed into is used in a bunch of different cars. So I would imagine that their hub could be pressed into Celica. Anyone know the bolt patterns?
Toyota Corolla
2004.05-2006.07; 4cyl 1.8L; S; SED; ; 2004.05-2006.07; 4cyl 1.8L; XRS; HB; ;
2003.05-2004.05; 4cyl 1.8L; XRS; HB; ; 2002.01-2003.05; 4cyl 1.8L; XRS; HB; ;
Toyota Matrix
Toyota TERCEL
2004.05-2006.07; 4cyl 1.5L; STD; 2DS; ; 2004.05-2006.07; 4cyl 1.5L; DLX; 2DS; ;
2004.05-2006.07; 4cyl 1.5L; DLX; 3DS; ;
Toyota Truck, Pickup
2004.05-2006.07; 4cyl 2.4L; DLX; ; T1; 2004.05-2006.07; 4cyl 2.4L; STD; ; T1;
2004.05-2006.07; 6cyl 3.0L; DLX; ; T1; 2004.05-2006.07; 6cyl 3.0L; SR5; ; T1;
2004.05-2006.07; 6cyl 3.0L; SR5; T1; ; 2004.05-2006.07; 6cyl 3.0L; DLX; T1; ;
2004.05-2006.07; 6cyl 3.0L; SR5; 2D; ; 2004.05-2006.07; 6cyl 3.0L; SR5; 4D; ;
2004.05-2006.07; 4cyl 2.4L; DLX; ; ; 2004.05-2006.07; 6cyl 3.0L; SR5; ; 4D;
2004.05-2006.07; 6cyl 3.0L; STD; ; T1; 2004.05-2006.07; 4cyl 2.4L; SR5; ; T1;
2004.05-2006.07; 4cyl 2.4L; DLX; T1; ; 2004.05-2006.07; 4cyl 2.4L; SR5; T1; ;
2003.05-2004.05; 4cyl 2.4L; DLX; ; T1; 2003.05-2004.05; 6cyl 3.0L; SR5; ; 4D;
2003.05-2004.05; 6cyl 3.0L; DLX; ; T1; 2003.05-2004.05; 6cyl 3.0L; STD; ; T1;
2003.05-2004.05; 4cyl 2.4L; DLX; T1; ; 2003.05-2004.05; 4cyl 2.4L; SR5; T1; ;
2003.05-2004.05; 6cyl 3.0L; SR5; ; T1; 2002.01-2003.05; 4cyl 2.4L; DLX; T1; ;
2002.01-2003.05; 4cyl 2.4L; SR5; T1; ; 2002.01-2003.05; 6cyl 3.0L; STD; ; T1;
2002.01-2003.05; 6cyl 3.0L; DLX; ; T1; 2002.01-2003.05; 6cyl 3.0L; SR5; ; T1;
Toyota Celica
2002.08-2005.07; 4cyl 1.8L; ; ; ; 1999.08-2002.08; 4cyl 1.8L; ; ; ;
1998.06-; 4cyl 2.2L; ST; CP; ; 1998.06-; 4cyl 2.2L; GT; CVT; ;
1998.06-; 4cyl 2.2L; GT; LB; ; 1998.06-; 4cyl 2.2L; ST; LB; ;
Toyota Tacoma
2002.08-2005.07; 4cyl 2.7L; DLX; ; ; 2002.08-2005.07; 6cyl 3.4L; DLX; ; ;
2002.08-2005.07; 4cyl 2.4L; DLX; ; ; 1999.08-2002.08; 4cyl 2.7L; DLX; ; ;
1999.08-2002.08; 6cyl 3.4L; DLX; ; ; 1999.08-2002.08; 4cyl 2.4L; DLX; ; ;
1998.06-; 4cyl 2.7L; DLX; ; ; 1998.06-; 6cyl 3.4L; DLX; ; ;
1998.06-; 6cyl 3.4L; SR5; ; ; 1998.06-; 4cyl 2.4L; DLX; ; ;
Toyota 4Runner
2002.08-2005.01; 6cyl 4.0L; SR5; ; ; 2002.08-2005.01; 6cyl 4.0L; LIMD; ; ;
2002.08-2005.01; 8cyl 4.7L; SR5; ; ; 2002.08-2005.01; 8cyl 4.7L; LIMD; ; ;
1999.12-2002.08; 8cyl 4.7L; SR5; ; ; 1999.12-2002.08; 8cyl 4.7L; LIMD; ; ;
1999.12-2002.08; 6cyl 4.0L; SR5; ; ; 1999.12-2002.08; 6cyl 4.0L; LIMD; ; ;
1998.06-; 4cyl 2.4L; DLX; V; ; 1998.06-; 4cyl 2.4L; SR5; V; ;
1998.06-; 4cyl 2.4L; DLX; T1; ; 1998.06-; 4cyl 2.4L; SRT; T1; ;
1998.06-; 4cyl 2.4L; STD; T1; ; 1998.06-; 4cyl 2.4L; SR5; T1; ;
Toyota MR2
2002.08-2005.01; 4cyl 1.8L; ; CVT; ; 1999.12-2002.08; 4cyl 1.8L; ; CVT; ;
#37 ·
^converting spacer will run about $400 for a complete set and they are 15mm. project kicks makes them. what the OP wants to do is a hub change to get a set a wheels with 5x114 pattern and then if he finds a different set he can get a different size or offset and not have to add or remove a large amount of spacers
#33 ·
True but there are special cases for different wheels.
For example, I have custom 18x9.5 nt03s in 5x100 which were only made in 5x114/120 but enkei can only produce custom wheels in bulk of 10 sets and i just happened to get them in a group buy.
But yea id rather hub swap then have 40 wheels.
#23 ·
Check the diameters of the rotors to see if they are the same.
Get a bare celica hub and a bare avalon hub and match the spindles to see if you can press the Avalon 5x114.3 hub to the celica knuckle.
HUB:
Knuckle
If the hubs match and only the bolt patter is different you shouldnt have a problem. You can have AUTOZONE even pull both out and look at it there, or even NAPA.
good luck, let me know if that'll work.
#20 ·
go big and do a tundra hub/brake swap
FAWK THAT! thats just insane, the calipers wouldnt fit :laugh: im not going for the break swap, im going for a hub swap!:eslap:
#15 ·
Well I tried looking for some pics and i found couple in the install guide for the front and rear. I dont see why we cant redrill the hub and rotor the but then i dont know if their is a downside to it :marky:
Rear
Front
<img src="http://www.newcelica.org/other/installs/aembigbrakes/index_files/image009.jpg"><br><br></td></tr><tr><td valign=top>5)<br><br></td><td colspan=2><font size=+1>
