from a dig, you can launch your gt, while the auto gts will crawl through half of it's rev range before even getting out of it's own way. by the time the gts gets moving the gt would be way out in front by then. from roll at 20 or 60, it would be a lot closer because from those speeds, the gts is about to hit lift (approx. 20-40 is 1st gear lift and 60-80 is 2nd gear lift) so instead of getting smoked, it'll at least keep up.
It's something I've always wanted to try though, just to see how bad the auto would get pulled by the 5 speed gt. :gap:
